[Progress Communities] [Progress OpenEdge ABL] Forum Post: RE: Transaction undo and life after logout
gus bjorklund
Tom: it /doesn’t/ need to be done the way it is done. like many things, there is more than one way to do it. there are also opportunities to optimise the present implementation. I won’t get into those here. George: i’ll explain as best i can. Remember that transactions are an /error handling/ mechanism. There are really four variants of undo in the client (plus two in the database, but that is another topic). they are: 0) undo triggered by an error condition detected in application logic and execution of an UNDO statement, 1) undo triggered by some error condition like a duplicate key, 2) undo triggered by a stop condition, 3) undo and termination triggered by an error detected by a signal handler. The LBI file is used to record client-side history so that some or all actions can be undone. In all cases, there may or may not be LBI reading to accompany the undo action. The LBI file is composed of one or more nested “ar units” or “action-recovery units”. An ar unit matches execution of a block in the 4GL. One ar unit may align with a block that has a database transaction and that does not have to be the outermost ar unit. Only one because database transactions cannot be nested in the 4GL. Subsequent ar units will be sub-transactions and their database actions may be recorded in the LBI file or not if database savepoints are being used by the client. Also, a nested ar unit may involve the start of a transaction on another database. When that happens, the second database transaction “joins” the outer one in a sense. While actions on the second database can be undone, that transaction can’t be committed until the outer database transaction commits. Along with block nesting, the LBI file is used to record values of local variables, temp table actions, database actions, buffer connections and disconnections and a few other items related to client side state information. During forward processing, the LBI file is buffered in memory and written sequentially when the buffer fills. When an undo happens, the LBI is read backwards from eof and a new eof established when the undo is finished. Depending on how much is being undone, the new eof may be at the beginning of the LBI or at the start of some block’s ar unit. When an undo happens, the undo may go back to any active ar unit. The target ar unit may be the same one that matches a database transaction, higher, or lower. In the first four cases mentioned above, the 4GL session will or can continue, depending on the application logic. The undo processing is very similar for all of them, except that a stop condition may be triggered by a lost database connection. In such a case, database actions in subtransactions cannot be undone by the client. undo must include the ar unit for the outermost database transaction but may go farther than that but not does necessarily stop the session. In the last case, the client session is going to be terminated due to a fatal error. much of the undo processing is the same as above, except that it goes all the way to the outermost ar-unit and then the client will exit. In some cases, depending on the type of error (e.g. an access violation), undo processing consists only of rolling back the database transaction followed by database disconnect and process exit. I’m sure I have left out something important but i cannot remember what it is. -gus
