OK. Thanks for the heads-up about the new version. I will recommend to the team that we not go to production until we upgrade to 11.7.2. It sounds like you aren't a fan of powershell. In that case I'm not sure why you used it at all. (It really isn't a direct equivalent to a Linux bash script.) As a side-note, if you like your Linux scripts so much, there may now be the option of running them directly on Windows (see msdn.microsoft.com/.../about) . This feature is probably not compatible with older windows servers, and I'm not sure if performance would be any better, but there would be less mismatch between how you develop your scripts, and your adminserver would operate more similarly between Linux and Windows....
