asthomas
Hey Carl, The extra parameters like assemblies will probably keep coming as other come across use cases we have not been working with on ARAT. You could probably also just add to the to the .pf file in the paramFile property ;-) That should actually handle most of these as they come up. With regard to the compiles, I am not aware that we are actually doing any lookups in the repo for the compiles from the toolkit. Do you get the same kind of reads on the rtb_pname table if you do the compile from RTB directly ? Or are you no longer doing that ;-)
