MBeynon
Hi, I ran my build with -v as suggested and piped the output to a txt file; ant -v build > log.txt It looks as though some files are being correctly identified whilst others are not!? So, UserTypeCreate.r has been identified as having no CRC changes and has not been copied from temp to compare which is correct. However, UserTypeObject.r has been identified as having a crc mis-match and been copied to compare which is incorrect as the CRC is the same. CRC UserTypeCreate.r File1 57,503 File2 57,503 CRC UserTypeDelete.r File1 24,126 File2 24,126 PLTarget UserTypeObject.r is an invalid rcode -- Resetting to invalid mark PLTarget UserTypeSelect.r is an invalid rcode -- Resetting to invalid mark PLTarget UserTypeUpdate.r is an invalid rcode -- Resetting to invalid mark --------------------------- Information --------------------------- Attribute: 1st 2nd RCODE-INFO CODEPAGE: ISO8859-1 ISO8859-1 CRC-VALUE: 17905 17905 DB-REFS: FILE-NAME: \build\rcode\compare\UserTypeObject.r \build\library\UserTypeObject.r HANDLE: 25 25 INST-PROC: ? ? IS-CLASS: no no LANGUAGES: MD5: 133C264217468EE41036A05BE46BBE63 133C264217468EE41036A05BE46BBE63 TBL-CRCS: TABLES: TYPE: PSEUDO-WIDGET PSEUDO-WIDGET MATCH: yes --------------------------- OK --------------------------- Thanks.
