[progress Communities] [progress Openedge Abl] Forum Post: Re: Pas To Emulate State-reset...
  • Thread starter Thread starter Blake Stanford
B
Blake Stanford
We are experimenting with replacing our classic appservers with PAS. I just did a test with classic state-reset where I created a global shared variable in the appservers startup procedure and gave it a value. I define the shared variable in the connect procedure and display the value in the appserver log. When I connect to the appserver the first time, the value is correctly displayed in the log file, when I disconnect and reconnect, the value is blank. I did the same with PAS using the bind, unbind, and quit statement and get the same results. I don't believe that anything which was created in the appserver startup procedure persists in a state-reset appserver once it gets reset.
