Mark Davies
Aha - well, that changes your approach then... Since JSON is seeing this as a string you will not be able to have the values inside the value as quoted strings - unless you escape them - which what QUOTER did. You will not be able to do that any other way if you want a double quote. The alternative is to rather use a single quote instead "'20y','','20 Year Membership',..." Not the best way to represent data I have to admit - a child object would have been a better approach in JSON.
