Garry Hall
As Gus pointed out, those tests are exercising the collation. The collation doesn't give you a string with the accents removed. However, the original question indicated the stripped string was for search purposes, so maybe (depending on what the application is) use of the collation is sufficient, and there is no need to strip the accents.
