[Progress Communities] [Progress OpenEdge ABL] Forum Post: RE: [DataDirect][ODBC Oracle Wire Protocol driver]Invalid character value. Error in column
jhobson
It appears that the columns are being incorrectly bound. From the log file, here are the columns descriptions (SQLDescribeColW). WCHAR * 0x04B9DED0 [ 2] "ID" SWORD * 0x04B9DE94 (3) SQL_DECIMAL SQLULEN * 0x04B9DE98 (12) WCHAR * 0x04B9DED0 [ 4] "NOME" SWORD * 0x04B9DE94 (12) SQL_VARCHAR SQLULEN * 0x04B9DE98 (40) WCHAR * 0x04B9DED0 [ 13] "TIPO_VENDEDOR" SWORD * 0x04B9DE94 (1) SQL_CHAR SQLULEN * 0x04B9DE98 (1) WCHAR * 0x04B9DED0 [ 6] "CODIGO" SWORD * 0x04B9DE94 (3) SQL_DECIMAL SQLULEN * 0x04B9DE98 (3) Here are the column bindings. DtsDebugHost 6314-5be0 EXIT SQLBindCol with return code 0 (SQL_SUCCESS) HSTMT 0x070765A8 UWORD 1 SWORD 2 PTR 0x0AB71FA0 SQLLEN 19 SQLLEN * 0x0070E4F0 (7380168) DtsDebugHost 6314-5be0 EXIT SQLBindCol with return code 0 (SQL_SUCCESS) HSTMT 0x070765A8 UWORD 2 SWORD 1 PTR 0x00709CC8 SQLLEN 2 SQLLEN * 0x057560D0 (91871608) DtsDebugHost 6314-5be0 EXIT SQLBindCol with return code 0 (SQL_SUCCESS) HSTMT 0x070765A8 UWORD 3 SWORD 2 PTR 0x0AB769E0 SQLLEN 19 SQLLEN * 0x0579D978 (91509080) DtsDebugHost 6314-5be0 EXIT SQLBindCol with return code 0 (SQL_SUCCESS) HSTMT 0x070765A8 UWORD 4 SWORD 1 PTR 0x0AB7B420 SQLLEN 41 SQLLEN * 0x0AB85450 (91509080) In particular, column 2 is bound with a size of 2 but the described size is 40. Column 4 is bound with a size of 41. So truncation seems likely. Column 3 is bound as a numeric but it's a character column. So an invalid character also seems likely. John
