Ramadevi Dhavala
Hi, You can use the "REST Resource URI Editor" to do your own mappings from PDS OE. Steps: 1. Open the REST Resource Editor, by simply double clicking on the rest service from the project explorer under "Defined Services" node. 2. Add a resource by clicking on add icon "+". Once the resource is added you can see the Verbs. 3. Click on the 3 dotted icon for any verb. It will launch you "Associate Operation with Verb" dialog. Select your "ABL file" under resources (ABL files has to be under APPServer folder) . Then select "ABL routines" (internal procedures). And say OK. 4. From the input tab -> right click on "Headers" node and click on "Add node...". 'Add Node' dialog will appear. Give some name and click on OK. 5. To the newly created node to the parameter from the right side, you can drag and drop the mapping. Please refer the attachments. Please get back to us if you are looking for any other information. Thanks, Ramadevi
