[progress Communities] [progress Openedge Abl] Forum Post: Public Variable
Arjon Policar
Dear Everyone, Greetings! Can you help me on the syntax of defining a public/global variable that I can access or use to the other forms, and also the syntax of using it to other form, for example I want to display it through a label that I create using the Visual Designer in Progress. Thank you, I hope you will help me. Arjon Policar
