martinpg2001
Hi _ I am new to Progress OpenEdge, so apologies if this is a simple question. I have installed OpenEdge 10.2B on a Windows 2003 Server. On this same machine, I want to define an ODBC source to connect to this server. Here is what I do:
1. Start Administrative Tools -> Datasources (ODBC).
2. Click System DSN.
3. Click Add, scroll down to select the OpenEdge 10.2B driver, and click Finish.
4. Enter a datasource name, enter the host name of this machine, enter 2055 for the port number, the name of a database I have created in openEdge, and then click Test Connect.
I see the following dialog box: [DataDirect][ODBC Progress OpenEdge Wire Protocol driver] Connection refused ... ErrNum = 10038
At this point, I don't know how to diagnose what the problem is - is some service that should be running not installed or running? Or have I entered the wrong port number (I tried a couple of others such as 2050 and 20932, but don't know how to identify which the correct port number should be.
Thanks for any help! Martin
