Hi,
I have connected a progress 9.1E database to another server via an ODBC connection. When I test the connection in windows it connects fine.
I then use the ODBC connection to connect to create a shared data source in SQL reporting services which test connects fine.
I then try to run a simple query on the database:
SELECT Site
FROM PUB.Prdtrx
and I get the following error message:
"Invalid attribute in connection string: user id. Exceeding permissible number of connections".
Is there any way to get around this? I can pull reports etc fine from Crystal reports using the same ODBC connection and credentials on another computer??
I have seen a "Maximum clients per server" setting in progress explorer for the database, but I dont want to touch it without knowing what it does...
SELECT Site
FROM PUB.Prdtrx
