How to get Product Struct level 3,4.5...
mosfin
your question is rather vague, i must say..anyway, if you are using version eB2.1 for example,
you can use menu 13.8.1 Product Structure by Item Report
and specify in the "Levels" criteria, any max level you want
Hi Mosfin,
Thank you for your reply, yes, iam using version eB2.1 and I know that report but...I want to get FG and lowest component level and qty per all phantom item
Exp
par comp qtyper
FG FG-1 0.5
FG-1 FG-2 2
FG-2 RM 1.5
The result I want to get:
par comp qtyper
FG RM 0.5*2*1.5
Anyone have good idea for this?
thanks in advance!
