How to enforce single logon in MFG/PRO eb2 sp3
egria
Hi,
My company is using MFG/PRO eb2 sp3. Users are using netterm to connect application.We are facing problem like user open multiple screen using same login.
Can anyone tell how to enforce single user logon ?:)
Thank you
You can use 36.3.24
Time out minutes
Enforce licensed user count
They help to reduce multiple logins. but you cant enforce it.
36.16.10.13. will help you report misuse to top management by user.
egria
Hi Kishor Chari,
Thanks for the prompt response. We done that already but It doesn't help ,cause people tense to use multiple login as they think is more conevience to them without concern on the license issue.
Is there anything that can detect login ID kick the older login ID out from the System
This doesnt work -> 36.16.10.13. will help you report misuse to top management by user ??
OK mail me on my email I will do something clever and give it to you.
egria
Hi,
"Can you enforce OS user id?Makes easy for my program. " ?
Sorry did you mean control user base on their windows logon ?
note: the MFG/PRO eb2 sp3 is running on linux & we using license base on connection
jaustria
Hi,
You need to do scripting to control user from login. I suggest you create a file where in you will list the user who can do multi login. If you require all of them to be a single login, just create the file.
You will check if the user id in the file you have created does not exist then your script will not allow him to pass through the database. In doing this, you need to have the menu where in you will put the validation before going through MFG/PRO.
JING
oldemanw
I use this in my client startscript (Linux box):
LIMIT=2
COUNT=`who | grep $LOGNAME | wc -l | awk '{print $1}'`
# If the user has more then $LIMIT sessions open, kick him/her out immediately
if [ "$COUNT" -gt "$LIMIT" ]
then
echo "`date +%y%m%d-%H%M` Login refused for $LOGNAME, limit $LIMIT" >> $LOGFILE
exit 1
fi
Hope it helps.
-Willem.
egria
Hi all,
Thanks for the feedback and greatly appreciate =).
I will try oldemanw's script. I'm new to the script stuff with linux box. how to I put in the script ? fyi, our clients PC is windows based and teh server is linux box
Thank you
Regards,
Nelson
sipek
Hi all,
Thank you
Regards,
Nelson
Dear Nelson,
Which distribution of linux you are using?
If you use RedHat / Fedora / PLD etc... you can use "Limits" done by Linux.
Try to find /etc/security/limits.conf ....
Best Regards
Sławek
egria
Dear Nelson,
Best Regards
Sławek
Hi Slawek,
Hmm interesting..gonna try this =)
Just got back from outstation. will let u all know tomorrow .LOL
egria
Hi all,
Sorry to tell you that it doesn't prevent ppl from login > than 1 session.
@test hard maxlogins 1
there is 1 testuser inside group test.
Server had restarted but still it wont stop ppl from having more than1 session to the linux server xD
I dont understand how stopping Linux logins will help you. You have mentioned your setup has different linux/mfgpro login id.
egria
Hi, The 1st login allow you to login to the linux's menu.sh before you can login into MFG/PRO. I 'm was hoping by limit number of netterm session to the linux prior to the MFG/PRO system would help. Thanks
