hi, i'm new here
please help
i want to set ODBC connection from Openedge 10.0B on Linux Redhat (15.59.254.91) to Borland Delphi 5 on Windows XP Pro.
database startup script:
/dlc/bin/_mprosrv /database/master/master -H localhost.localdomain -Mn 3 -Mpb 4 -N TCP -Mi 1 -Ma 5 -S 30071 -n 25 -cpinternal ibm850 -cpcoll basic -L 1024000 -c 250 -B 13500 -d dmy -yy 1980 -numsep 44 -numdec 46 -rereadnolock
/dlc/bin/_mprosrv /database/master/master -H localhost.localdomain -m3 -Mpb 2 -Ma 5 -Mi 1 -N TCP -S 30079 -n 25 -cpinternal ibm850 -cpcoll basic -L 1024000 -c 250 -B 13500 -d dmy -yy 1980 -numsep 44 -numdec 46 -rereadnolock
[root@localhost ~]# upmaster
09:35:05 BROKER 0: Multi-user session begin. (333)
09:35:05 BROKER 0: Begin Physical Redo Phase at 0 . (5326)
09:35:05 BROKER 0: Physical Redo Phase Completed at blk 0 off 1473 upd 0. (7161)
09:35:05 BROKER 0: Started for 30071 using TCP, pid 7400. (5644)
09:35:05 BROKER 1: Started for 30079 using TCP, pid 7402. (5644)
09:35:05 BROKER 1: This is an additional broker for this protocol. (5645)
09:35:05 BROKER 1: This broker supports both 4GL and SQL server groups. (8865)
[root@localhost ~]# $DLC/bin/slib_env
[root@localhost ~]#
[root@localhost ~]# $DLC/bin/java_env
[root@localhost ~]#
[root@localhost ~]# ldd $DLC/bin/_sqlsrv2
libprosqlsnd.so => /dlc/lib/libprosqlsnd.so (0x002fa000)
libprosqlrds.so => /dlc/lib/libprosqlrds.so (0x00998000)
libprosqlsnw.so => /dlc/lib/libprosqlsnw.so (0x00fde000)
libprosqlgeneric.so => /dlc/lib/libprosqlgeneric.so (0x00111000)
libprosqldb.so => /dlc/lib/libprosqldb.so (0x0041d000)
libprosqlmm.so => /dlc/lib/libprosqlmm.so (0x001cb000)
libpronls.so => /dlc/lib/libpronls.so (0x0079e000)
libprosqlss.so => /dlc/lib/libprosqlss.so (0x0037e000)
libprosqljava.so => /dlc/lib/libprosqljava.so (0x00276000)
libprosqlos.so => /dlc/lib/libprosqlos.so (0x00402000)
librocket_r.so => /dlc/lib/librocket_r.so (0x005ac000)
libusort.so => /dlc/lib/libusort.so (0x001fb000)
libjvm.so => /opt/jdk1.3.1_12/jre/lib/i386/classic/libjvm.so (0x00479000)
libhpi.so => /opt/jdk1.3.1_12/jre/lib/i386/native_threads/libhpi.so (0x00e35000)
libnsl.so.1 => /lib/libnsl.so.1 (0x001fe000)
libpthread.so.0 => /lib/tls/libpthread.so.0 (0x00214000)
libcrypt.so.1 => /lib/libcrypt.so.1 (0x00226000)
libdl.so.2 => /lib/libdl.so.2 (0x0068d000)
libstdc++-libc6.2-2.so.3 => /usr/lib/libstdc++-libc6.2-2.so.3 (0x006c6000)
libm.so.6 => /lib/tls/libm.so.6 (0x00693000)
libc.so.6 => /lib/tls/libc.so.6 (0x007ac000)
/lib/ld-linux.so.2 (0x00549000)
libgcc_s.so.1 => /lib/libgcc_s.so.1 (0x00255000)
i already do this : stop firestarter service, create _user : SYSPROGRESS with blank password
i think all path are ok, but when i try to connect from ODBC win XP using Data Direct 4.20 32-BIT OpenEdge SQL v10.0B
Data Source Name : testing
Host Name : 15.59.254.91
Port Number : 30079
Database Name : master.db
User ID : SYSPROGRESS
i got error : Server not Respond
when i try on Linux:
[root@localhost ~]# sqlexp -char -H localhost -S 30079 -db master -user sysprogress
PROGRESS Version 9.1E as of Tue Oct 12 14:40:19 EDT 2004
Connecting user "sysprogress" to URL "jdbc:jdbcprogress:T:localhost:30079:master"... (8920)
Error: No suitable driver. (8933)
See "/root/sqlexp.log" and "/root/SQLExplorer.exceptions" files for more information. (8950)
/root/sqlexp.log
[1/8/10 8:43:31 AM]
[1/8/10 8:43:31 AM]=== Start logging. Local time: 1/8/10 8:43:31 AM. ===
[1/8/10 8:43:31 AM]
[1/8/10 8:43:31 AM] [3] [SQLExplorer] Default properties will be used. (SQLMsg037)
[1/8/10 8:43:31 AM] [3] [SQLExplorer] Setting Connect to jdbc:jdbcprogress:T:localhost:30079:master
[1/8/10 8:43:31 AM] [3] [SQLExplorer] === SQLExplorer starting. ===
[1/8/10 8:43:31 AM] [3] [SQLExplorer] ### ARGS: -char -H localhost -S 30079 -db master -user sysprogress
[1/8/10 8:43:31 AM] [3] [SQLExplorer] Connecting user "sysprogress" to URL "jdbc:jdbcprogress:T:localhost:30079:master"... (8920)
[1/8/10 8:43:31 AM] [3] [SQLExplorer] Loading JDBC driver com.progress.sql.jdbc.JdbcProgressDriver.
[1/8/10 8:43:31 AM] [0] [*UnexpectedError*] * recorded as exception #1 in file /root/SQLExplorer.exceptions.
[1/8/10 8:43:31 AM] [3] [SQLExplorer] === SQLExplorer ending. ===
====== Start exception logging == "/root/SQLExplorer.exceptions" opened == Fri Jan 08 08:43:31 JAVT 2010 ======
**** 1 ****
Exception at Fri Jan 08 08:43:31 JAVT 2010: java.sql.SQLException
Message (throw): ### Connect stack trace. ###
Message (excp): No suitable driver
Stack Trace:
java.sql.SQLException: No suitable driver
at java.sql.DriverManager.getConnection(DriverManager.java:532)
at java.sql.DriverManager.getConnection(DriverManager.java:172)
at com.progress.sql.explorer.SQLConnectServer.call(SQLConnectServer.java:37)
at com.progress.common.rmiregistry.TryIt.run(TryIt.java:186)
whats wrong with my setting? please advice
thanks a lot
Denny
please help
[root@localhost ~]#
[root@localhost ~]#
Port Number : 30079
/root/sqlexp.log
[1/8/10 8:43:31 AM]
[1/8/10 8:43:31 AM]
**** 1 ****
Stack Trace:
thanks a lot
Denny
