Forum Post: Re: Is It Possible To Integrate Aspose
Alon Blich
I've pasted the overview from the website below but you can download the tutorial and browse through the table of contents to get a better idea. The tutorial also covers installation and setup. I am an openedge not a rollbase developer but I would be more than happy to get in touch with someone from rollbase to help set it up. Simple to Use - To create a .DOCX file, design a template (regular .DOCX file) and merge your data with the template using your favorite programming language. No technical knowledge of the .DOCX file format (Open XML) is required. Powerful - Does alot more than simply inserting values and creating simple letters, it allows you to truly create real world, sophisticated reports with barcodes, charts, pictures, table of contents, paging features and much more. Well Documented - The tutorial walks you through howto create documents and all the library features. Multiple Formats - Supports generating many different document formats, like, PDF, OpenOffice/LibreOffice, HTML as well as printing. Barcodes - Supports practically every 1D and 2D barcode in the world, like, Code39, Code128, EAN, UPC, ISBN, Databar, Postal Codes, PDF417, Data Matrix, QR Code, Maxi Code and many more. Charts - Supports the entire list of more than 70 chart types and all their variants in Microsoft Word, like, Column, Line, Pie, Bar, Area, Scatter, Stock, Surface, Doughnut, Bubble and Radar charts. Fast - Create a .DOCX file in milliseconds and millions of files per day. Free - DocxFactory is Freeware. It is completely free for private and commercial use without any time or feature limits. The project will be open sourced this year. Cross Platform - Available on Windows and UNIX/Linux. Hope this helps.
