Forum Post: Re: creating progress openedge object in rollbase using data-direct
  • Thread starter Thread starter Bill Wood
B
Bill Wood
DataDirect Cloud only uses SSL if you connect directly to the OpenEdge DB. If you wish to go this route, then you have to enable SSL (which also involves providing valid certificate) when you start your SQL server for OpenEdge. Personally, i would recommend not doing the direct connect from DataDirect Cloud and instead using DataDirect Cloud On-Premise Connector. You may want to post questions on the DataDirect Cloud forum while you are having trouble with the non-Rollbase section. More experts in DataDirect Cloud configuration monitor that forum. (Though we will certainly do our best to support you here. ;-) To set up SSL for OpenEdge (if you really want to go that route) you should check up the the OpenEdge documentation and the k-base. I know there are some good entries on this on the knowledge base.
