Hi Friends,
I have a wrapper program written with below format.(Developed in MFGPRO eb sp2) CHUI.
on go, tab, return anywhere:
if frame-field = "ap_po" then do:
update x y z with overlay frame b.
end.
end.
{gprun.i "apvomt.p"}
We are converting them into .Net compatible.
I have some issues in the navigation in .Net SE 2011
My problem is, If you are pressing "Enter" in the customized overlay frame the particular "form / frame" is being submitting and the user is not allowed to enter values in the standard qad fields.
Here My question is "Is there any way where we can focus the cursor in standard QAD field after pressing "Enter" in the "Overlay frame". something like "Apply Entry".
Please advice. Thanks in advance !
end.
end.
