Ok, big question this one:
I want to create a report model project in MS Visual Studio 2005, connecting to a Progress Openedge Database.
I can successfully connect to the progress database, and pull some data from SQL Reporting Services. However, when I try to create a report model project, I get errors.
Firstly, I create a new data source, and test the connection, and it works fine. The Connection method is ODBC, using "Progress Openedge 10.2A Driver".
I then attempt to create a Data Source View. I can see the tables, and choose which ones I want to include, however, when I click finish, I get the following error:
ERROR [HY000] [DataDirect][ODBC Progress OpenEdge Wire Protocol driver][OPENEDGE]Syntax error in SQL statement at or about "[PUB].[AHFaultAction]" (10713) (pgoe1023.dll)
Program Location:
at System.Data.Odbc.OdbcConnection.HandleError(OdbcHandle hrHandle, RetCode retcode)
at System.Data.Odbc.OdbcCommand.ExecuteReaderObject(CommandBehavior behavior, String method, Boolean needReader, Object[] methodArguments, SQL_API odbcApiMethod)
at System.Data.Odbc.OdbcCommand.ExecuteReaderObject(CommandBehavior behavior, String method, Boolean needReader)
at System.Data.Odbc.OdbcCommand.ExecuteReader(CommandBehavior behavior)
at System.Data.Odbc.OdbcCommand.ExecuteDbDataReader(CommandBehavior behavior)
at System.Data.Common.DbCommand.ExecuteReader(CommandBehavior behavior)
at Microsoft.DataWarehouse.Design.DataSourceConnection.FillDataSet(DataSet dataSet, String schemaName, String tableName, String tableType)
at Microsoft.AnalysisServices.Design.DSVUtilities.ExportDataSet(DataSourceView& dsv, DataSourceConnection conn, ArrayList tableList, ArrayList viewList, ArrayList sysTableList, ArrayList sysViewList, IServiceProvider serviceProvider, ProgressBar progressBar)
at Microsoft.AnalysisServices.Wizards.DSVWizardForm.OnFinish(CancelEventArgs e)
Doing a bit of searching around, and I have found this is most likely an issue with SQL putting square brackets around the statement, which Progress doesnt recognise.
Relevant topic: http://www.progresstalk.com/showthread.php?p=351153
Is there any way to fix this?
I am really doing my head in with this problem. It is holding back some major advances...
Program Location:
