Rob Fitzpatrick
Also check promon to ensure that all servers that should be able to spawn are able to. Check the DB log for errors related to spawning servers. Note that the broker won't spawn a 4GL server on a port if it is defined in the OS services file, even if it isn't currently in use. Check that there aren't defined services with port numbers within your minport/maxport ranges.
