How to set Primary key for DB using Data Dictionary
Manu
Hai All!
I am trying to create a new table using data dictionary. How can i set prmary key for that table? I am not finding ne such option in either field or table widget?
Also direct me if there are any help regarding DB related issues in Progress.
ne help is appreciated.
Rgds
Manohar
Data Dictionary => Index Properties and the field is "Primary".
If you have only one index is always primary, if you have more you have to choose which one to want to set as primary and just simple click on field "Primary".
Regards,
Istvan
