SQL-statement causes stack-problem
Luukh
Today I've written a program with roughly the following syntax:
for each customer no-lock:
select count(*) into vtotal from orders
where order.cust_id = customer.cust_id.
if vtotal < 5 then next.
for each order where order.cust_id = customer.cust_id no-lock:
display order.
end.
end.
when I run the program I get an error about the -s parameter.
When I replace the select count statement with a:
for each order...
assign x = x + 1.
end.
there's no problem.
Does anybody know what the problem is?
And is this some sort of incompatibility between Progress and SQL?
TIA,
Luuk
Chris Kelleher
Administrator
Staff member
Luuk-
Hi there. I suspect that your problem is related to the fact that you are using FOR EACH (4GL) and SELECT (SQL) in the same block. I would recommend either using all 4GL record statements or all SQL, but I wouldn't mix and match both in the same procedure.
HTH.
-Chris
Chris Schreiber
ProgressTalk.com Manager
chris@fast4gl.com
zhonghong
For each is a Progress statement which acquires one row at a time, whereas select is a SQL statement usually returns a dataset, don't mix them up.
<BLOCKQUOTE><font size="1" face="Arial, Verdana">quote:</font><HR>Originally posted by Luukh:
display order.
end.
end.
for each order...
assign x = x + 1.
end.
there's no problem.
TIA,
Luuk
<HR></BLOCKQUOTE>
