Printer escape codes in a frame?
Kade
UNIX Environment:
I'm using a code generator, to generate reports and invoices. I generate the forms based on the users choices of fields to include. I need the ability to use bold, underline, ....
I know "put control" works for this, but I can't see an easy method to incorporate forms.
Is there a way to assign the current view of a form to a variable? I could then use substring and several put/put control statements.
:confused - Any suggestions would be appreciated.
