Hi All,
I hope someone might be able to help me with a problem running a procedure in our progress app, as sending me insane.
Our application runs in windows with the progress database on a linux server. i am calling a procedure from within my application which errors with "4GL Stop Condition: The server application returned an error 7243, 7241"
When i check my log file i see the following:
[06/04/06@10:15:53.494+0100] P-014984 T-000000 2 AS AS -- TRACE: PERSISTENT Procedure 'bo/DynamicQuery.p' START. (5497)
[06/04/06@10:15:53.511+0100] P-014984 T-000000 3 AS AS -- TRACE: PERSISTENT Procedure END SUCCESS. (8396)
[06/04/06@10:15:53.559+0100] P-014984 T-000000 2 AS AS -- TRACE: Internal Procedure 'ExecuteDashBoardQuery' (in 'bo/DynamicQuery.p') START. (5499)
[06/04/06@10:16:00.685+0100] P-014984 T-000000 1 AS -- (Procedure: 'getQueryData1 bo/DynamicQuery.p' Line:29704) ** "/data/epicor/mfgwrk80/baq345122425.r" was not found. (293)
The procedure runs but seems to stop when it can not find the required file. On checking this it looks as if the mfgwrk80 folder is not being found or written to.
In my .pf file i have the following:
-db /data/epicor/mfgsys80/db/mfgsys -T /data/epicor/mfgwrk80
-Mm 1024 -mmax 4000 -Bt 200 -s 200 -yy 1970 -stsh 31 -inp 32000 -tok 4000
As far as i can see things look ok and i can not see why my procedure fails. If anybody has experienced something like this or can suggest somthing for me to try i would be very thankful.
Regards
Richhsp
Regards
Richhsp
