Mani Rathinam
Hi all,
I am having a strange behavior with reports of MFG/PRO. I had copied few tables from one database to another. And now i need to check with the reports to make sure that the new database s perfectly correct. I ran report for the older one and with the new database too. When i took the reports and compared them both, for few records alone there are some differences. That is, If a record has 2 lines, the lines got swapped in the other database. But when I run the query for a particular record, Both are perfect and same without any change in order. And one more thing is, If i give the selection criteria and run for few records, I am getting the reports of both databases same. Programs for both reports taking from same pro path so no bug in program I hope so. Pls, If anyone come across this issue or know about this pls let me know. Thank you.
