Gian Torralba
Hello, If you are using a Private Cloud Installation, You can set it to your desired value since there are no limits specified in the Rollbase User Guide. Take note that performance will also be affected if you try putting all triggers in a single process at once. I suggest you do a stress test on that process to see the impact of the trigger execution on your system. Creating separate process for creating and updating records is also one way to reduce the trigger running at the cost of users doing more actions in the application. Thank you, Gian
