Forum Post: Re: creating progress openedge object in rollbase using data-direct
W
wood
The documentation is pretty good on DataDirect Cloud integration with Rollbase. OpenEdge is just one data source possible. The first thing to do is to start a d DataDirect Cloud account with OpenEdge. I would recommend the DataDirect Cloud On-premise Connector option though (otherwise you need to have SSL on your OpenEdge DB which adds some complexity). Have you set up and tested an OpenEdge on-premise datasource and tested it with the DataDirect Cloud SQL Tester ? You should start there (and look in the DataDirect Cloud community for advice and questions on that). =
