tbergman
I'm converting the following code snippet to Progress. I got it to work but my solution seems a bit inelegant. ImageConverter _imageConverter = new ImageConverter(); byte[] xByte = (byte[])_imageConverter.ConvertTo(x, typeof(byte[])); return xByte; Note that the second parameter of the ConvertTo method has to be a System.Type. What I ended up doing was defining a Byte[] and then using GetType against it. This works but I had to new a byte array and it seems like there should be a cleaner way. Is there something in Progress that's like the C# Typeof command, the Progress Type-Of statement returns a logical, not a System.Type. DEF VAR x AS "System.Byte[]" . x = NEW "System.Byte[]" ( 0 ). RETURN CAST (oConverter:ConvertTo(pImage, x :GetType()), "System.Byte[]" ).
