Question ComponentOne controls - registration‏ problem
Rick C
Has anyone run into a problem where they get the following: "This dialog box will not be shown if you recompile the program using a licensed version of this product." out of the V8 FlexGrid (or, indeed, any of the other controls?) We have a customer who bought two supposedly-identical Acer Windows 7 boxes and installed our product. On one, everything works fine. On the other, when you try to run the application, you get this warning. The computer with the problem had UAC turned off, and I thought that might be related to the problem, so I turned it on, reinstalled our software as administrator, and manually reregistered the control from an Administrator command prompt, but that didn't work.
Nothing but the ocxes is installed on the client PC; all r-code is on a network share and the db resides on a server. Progress 9.1D08 (yes, I know) on both machines.
